Lowsuv
Oct 17, 2013Explorer
There are many tire threads on this forum .
You can get a lot of info from doing a search.
The most logical way of decreasing your risk is to replace your tires with a tire that has a higher load weight rating as posted on the sidewall .
You most likely have a tire that is a "Load Range C " tire .
You can change to a "Load Range D " or even "E " and improve your safety reserve margin .
You can also simultaneously change to a 225 / 75 R 15 tire in a load range D or C if you have adequate clearance under your wheel wells .
The charts at Tire Rack are your friend .
You can do a search for "trailer tires" or just search for tires in size 205 /75 R 15 or 225 /75 R 15 and then click on "specifications " to get all of the data that you need .
My trailer had enough clearance for 225 /75 R 15 instead of 205 /75 R 15 .
The tires are the weakest link .
By adding reserve capacity tires you will reduce your odds of failure due to overloading .
44,068 PostsLatest Activity: Jun 10, 2026
