swallow's avatar
swallow
trailer vers 5th wheel
Hi I am thinking of getting a artic fox 32a or a 280 blackstone I have a 29 foot 5th wheel but I would like to take a atv in my 8 foot box and toy haulers are big and only have a couch unless you get a 45 footer.My truck is a 2012 chev dually .My question is do they track,ride as good ,are they going to drag when going through dips because they seem to sit lower to ground and over all length seems long compared to my 5th wheel. what do you think thanks
  • Travel trailers tow as well as a fifth wheel given the truck, trailer, and hitch are set up properly.
    People think a fifth wheel can't sway and that is simply not true. Fifth wheels tend to not sway because of the incredibly heavy pin weight (20- 25 ish % of the trailer weight rating is on the pin). Travel trailers tend to run 12-15% ish on tongue weight.
    I personally like travel trailers because they generally have a lower center of gravity, the attachment point is lower to the ground (easier for me to reach) and I can still use the bed of my truck while pulling.
    thanks!
    Jeremiah
  • I had a 35ft Jayco fifth wheel and I can say, fifth wheels do tow better than trailers but it isn't that much of a difference. In comparison, I had a ft 34 Terry trailer and it towed well with the equalizer hitch and sway bar but not as good as the fifth wheel especially on windy days.
    Unlike the trailers of old, most of these newer ones have plenty of clearance. Haven't scrapped the rear of mine yet and most all of my travels are off road in the hills with lots of dips getting to a camp. My 34ft Terry used to scrape all the time.
    Taking am ATV along is important to some. My son and I yesterday in his truck with a 700 Grizzly in the back and a 24ft Security trailer.
  • Don't characterize ALL travel trailers as sitting lower than 5th wheels. Many brands and models are built on top of the axles exactly as most 5th wheels are built and would have the same ground clearance. Also don't characterize all toy haulers as needing 45 feet to get a full time bed. Sounds like you just need to look at some different brands and models than you've looked at so far.
    Good luck / Skip
  • Artic Fox and Outdoors RV trailers have some of the best ground clearance going. They both claim off-road capability with shocks and strong frames.
    But some TT hitches seem to have lower ground clearance than others, depending upon how they are set up. That might be an issue?
  • Generally speaking a TT is more susceptible to sway than a 5'er. Also the TT will back/swing very differently than the 5'er. Like apples and oranges, both are trailers but they are not alike.
  • I have no experience with a 5er but pulled my 31 ft. TT over 7K miles last year with no problems. Never did bottom out and had no sway or pulling problems. Pulling with Nissan 1/2 ton. I think much lower profile helps with wind etc. not nearly as high as some 5ers.
