TWolf
Jun 10, 2013Explorer
Trailer wagging
I have a 2013 Rockwood TT lite. It is 26 foot long. I traded my 04 Nash on it. I never had any problems towing the Nash which dry weight was 8300 lbs. The Rockwood which its dry weight is 5717 and...
RinconVTR wrote:TWolf wrote:
I have an EQ hitch and had it set up to my current truck. The truck is a 03 Chevy 2500HD D-max crew cab short box. When I first bought the TT, I had a 99 Ford 250 crew cab short box and it did the same thing. The hitch was lowered and tilted more flat than forward. I bought the hitch used in 98 when we bought our first TT. Can a hitch wear out? The fresh water tank in behind the wheels and the gray/black is over the wheels. I also have a bumper rack which holds my Honda 3000 generator.
If it is to little tongue weight, how can I solve this issues with out moving my generator. It also had the same issue without the generator. We do a lot of dry camping here so I need both the generator and a full tank of water.
The TT is a front kitchen unit.
Get'er weighed before you worry too much.
The Honda 3000 on the back bumper is definitely a something to look at though. Its around 150lbs gassed up, which is more than 2 bikes and a bike rack (80-100lbs typical). You could simply remove it and take'er for a drive to see. I'd be surprised if that single item corrects the issue for you, because of the severity you describe.
