lanerd
Jan 19, 2017Explorer II
patriotgrunt wrote:
I used to tow a 4000 lbs bass boat behind a 3/4 ton Dodge and I never knew it was back there. Later, I sold the Dodge and went to a very capable F-150. It towed the boat fine but I definitely knew it was back there. I could feel it as I drove and especially when I came to a stop. I then traded that truck in for a 3/4 F-250 and again I tow that boat without knowing its back there. Now imagine three times the weight and how much the difference in towing will be.
Although the 1/2 ton can do the job, the 3/4 ton is just built to tow. It's much more capable, stable, and safer.
There is a HUGE difference between pulling a bass boat with little or no appreciable tongue weight than a TT with a 1000 lb tongue weight. Apples and oranges.
I'm sure the main issue here with the OP would be the payload capacity of the tow vehicle. Once you load the trailer/hitch plus people, animals, tools, camping equipment, etc.... you will be at or over the 1/2 ton payload capacity and probably the RAWR also.
Ron
44,056 PostsLatest Activity: May 04, 2014
