aftermath
Jun 18, 2016Explorer III
JIMNLIN wrote:
I've bought and worn out dozens of tires on trailers and have never had them balanced.
Now I have felt viberation at times especially when those tires on the trailers usually has 40k-50k miles. A simple visual inspection showed the tread belts were split and separating.
Time to find out why the tires are suddenly causing vibrations.
And also I've had wheel issues also causing vibrations such as split tire bead seat on the rim and cracked centers/loose lugs/etc.
"Never had them balanced." Is it only a problem when you can feel it in the truck? By running unbalanced tires over a long period do you suppose that could have been part of the cracked centers, loose lugs, etc. that you referred to?
Some facts here. An unbalanced tire will produce vibration while going down the road. Vibrations will be transferred to the vehicle.
Lets not get into a discussion of a truck vs a trailer and how much vibration will be felt, vibration is vibration, degree not withstanding. Vibration over time will create some serious issues. How many threads do we read about people unhappy with their trailers when screws come loose "for no reason", cabinet doors don't close like they should, moldings start to separate, plumbing connections start to leak and on and on?
I own an Airstream and the design creates special concerns for us. Shaking an Airstream will result in popped rivets, loose screws, open drawers to name a few problems. The skin is connected to the frame and acts like a unified body. Shake the wheels, you shake the entire trailer.
It is imperative to reduce, or remove, shaking of the trailer. Balancing tires is not a perfect solution and that is why many use centramatics and those bead balancers after balancing their tires. While balancing tires is not perfect it is a good place to start and the cost is relatively small when compared to the cost of damages caused. After I took possession of my slightly used trailer I noticed drawers open after we got to our destination and a few popped rivets. I replaced the tires, made sure they were balanced and all those issues went away. You certainly don't have to balance your tires but it doesn't hurt. I guess if you can't feel it shaking then it must be just fine.
