GoldWingRyder
Jul 21, 2016Explorer
From Etrailer
Tire Balancing
At etrailer.com, our tire and wheel combinations are mounted so that the high heavy spot on the tire is aligned with the low light spot on the wheel. This provides adequate balance for trailer tires.
If you buy new tires for a set of rims, you can have them balanced. If you do balance trailer tires, remember that many trailer wheels are centered by the position of the lug bolts (these wheels are lug-centric) and not the center bore of the wheel. To get the best tire balance for lug-centric wheels, you should have them balanced using a pin plate adapter. This mimics the way a lug-centric wheel is mounted to a hub.
Tire Balancing
