MisterCipher's avatar
MisterCipher
Trailer Width - Pros and Cons
I'm shopping for a travel trailer that I can tow with the Toyota Highlander which just has standard side mirrors. I'm seeing widths from 90 inches to 102 inches. I'm concerned if I go too wide I'll need to use side mirror extenders which I'd prefer to avoid.
Are there advantages to narrower trailers? Or should I try to get the widest possible to maximize interior space?
    Yes, you won't need side mirrors.
    Also, with the Highlander being a relatively "mid-sized" SUV, I wouldn't want to tow anything wider than 90" or 96"
    102" is out of the question
  • My TT is 7 1/2 feet wide (90 inches) and I use mirror extenders. They work fine and provide extra vision to the rear but I probably could "get away" without them. Easy to put on and take off. Once the right hand one is adjusted...piece of cake.
  • I've owned both 90" and 96" TT (not sure of the width of one of my trailers);
    I would not let the use of mirror extenders dictate the choice of TT. The floor-plan/weight/length etc should dictate the choice.
    I currently have a 90" toy hauler and coming from a 96" TT, the TH does feel more
    compact. My next camper will be 96" or greater.
    HOWEVER - one advantage of a narrower TT is that it presents a smaller profile to the wind, which may or may nor matter.
  • If you dont want mirror extensions, then be prepared either for tickets, or no trailer. You absolutely MUST have a clear view behind you. It is the law afterall. So your choice is pretty clear.
  • DutchmenSport wrote:
    You will want extended mirrors, no matter what you tow.
    X2.
    And I would not let a few inches either way scare me off of a rig I like.
  • I sure wouldn't choose any trailer less than 8' wide just so I could potentially avoid using towing mirrors. Regardless of what mirror solution you choose more interior space is always an advantage, especially with any trailer that doesn't have a slide.
