JGage's avatar
JGage
Trailer with fixed coupler so it doesn't pivot
Please be gentle with me as I'm fairly inexperienced with towing. I have a small utility trailer with a size small enough that I find it almost impossible to see in my mirrors when backing. Unable to see how it's pivoting, I'm nervous about attempting to back unless I have a spotter (which I don't always have).
So what I thought might exist out there is some sort of trailer coupler that works like a regular pivoting ball mount most of the time, but that can be "locked" in to place when required, sort of making it like a non-pivoting extension of the vehicle it's attached to. That way I'd have less to worry about how it's pivoting while backing because I'd know that wherever the corner of my vehicle is (which I can see in the mirror), the trailer is right behind it on the same path.
I've been looking in various forums for days and everybody gives me bewildered, "uh, why would you want to do that?" replies. Maybe what I'm thinking of doesn't exist? If that's the case, maybe somebody can educate me on why it would be a bad idea? About the closest I can find so far is something like an anti-sway coupler where you could tighten down the sway bars hard enough that you could lock out most of the pivot.
If anyone has advice, I'd appreciate it.
  • I have a 4x8 foot utility trailer which is almost impossible to back up without the ramp on and in up position. Boat trailer same problem. Like others said just make a temp flag for the back corners. Will make like life a lot easier.
  • I did find something called the Hensley Cub hitch, which as I understand it completely locks out the pivot point at the hitch and transfers it to the trailer wheels. But it's also overkill at over $1000. Probably just need to stick to plastic poles.
  • I used 11/2" plastic pipe and 2 45deg fittings on my wave runner. I didn't glue the outriggers so they were removable.
    Mark
  • Thanks. That could very well be why I can't find anything. Something that's never been invented isn't going to be on Amazon.
    Maybe I'll have to look in to this mounted pole as an alternative.
  • I've never seen one like that. About all you can do if you don't have a back-up camera is to mark the corners of the trailer with poles/pipe that sticks up high enough for you to see when backing and you just watch the poles/pipes. I've seen little fiberglass poles with magnetic mounts that could be used for this purpose. I used to have to back a log splitter that would completely jackknife before you could see what was happening. Not fun.
