Bobmontana's avatar
Bobmontana
Trans coolers
While towing our 3000lb travel trailer with our 2011 Yukon xl 1500 5.3 litre I found that it does ok for the most part but the transmission did get up to 220 degrees going over Macdonald pass in Montana. We were down to 45mph and 3000 rpm just as we crested over and the trans gauge touched 220. Has anyone replaced the stock cooler with a larger one that is a OEM ? I don't like the idea of scabbing in a cooler attatched too the radiator and just rubber hose clamped to the lines. Than you for your time.
