Pool
Jun 01, 2013Explorer
Trans temp
I watch the Trans temp while towing and curious what a good range is to make sure it is not too hot. I have a factory front mounted trans cooler on a four speed 5.3 engine. Normally runs about 176 - 1...
Cummins12V98 wrote:USMarine0369 wrote:
I have a heavy duty transmission in my Ram with a 91% lock torque converter and low stall. In stop and go traffic mine will reach 200. Once I move it goes down, but in the city on hot days it will stay between 140 and 180 depending on my movement.
I installed a fairly large 2nd cooler in line with the factory one. I don't know why the Chevy guy would tell you that is a bad idea. You might want to bypass your factory cooler and just use an external one, as I think your factory cooler is routed through your radiator.
I also run Amsoil ATF in it and change it about every 16-20,000 miles.
You should look at your radiator and see if it is plugged up with road grime.
I'll try and post a pic of what mine looked like before I cleaned it out.
I am guessing by your pic you have a 2nd gen 24V.
Go thru the factory cooler first then the added cooler that way the oil get's warmed up.
