poncho62's avatar
poncho62
Trans temperature gauge
OK, heres the deal...I installed an Autometer tranny temp gauge in my truck this morning...4L60 trans....Its about 35-40 degrees around here, winters coming...Went into town to run a few errands. Temp on gauge went to about 125F, that was about it. Ran a total of about 10 miles. Is this normal for this time of year?..How long should it take to get up to operating temp this time of year, or is this the normal temp for this time of year?
Just trying to get a baseline here, as I have never monitored trans temp before.
  • The Dexron 6 has been tested up to 285 degrees-
    In the February 2011 issue of Trailer Life magazine RV Clinic in response to a reader about the maximum transmission temperature allowed in a 2009 Chevy Silverado, the Tech Team had this response.
    “General Motors’ in-house towing team expert provided RV Clinic with this statement: The maximum allowable automatic transmission fluid temperature is dictated by the transmission oil itself. The oil begins to degrade significantly above 270 degrees Fahrenheit, so we design vehicles so that in all but the most extreme conditions, the fluid temperature in the transmission sump stays below 270 degrees F.
    We allow for up to 285 degrees F in extreme conditions (i.e. towing a trailer with combination loaded at GCWR in Death Valley). But for customer usage anywhere else in the country, even at GCWR, transmission sump temperature should stay well below 270 degrees F. Above this point, certain internal components, such as seals, begin to disintegrate rather quickly. Although newer synthetic fluids can withstand higher temperatures we still recommend this (270F) as a maximum temperature. "
  • Sounds about right. It will get warmer in the summer. My 4l60 will hit 190 towing in the summer.
  • Never used a 4L series, but the temp sound reasonable. You want them warm, and that is not unusually so. I would expect the transmission to get warm in 4 or 5 miles
  • On the average...ALL of my GM's have run about 100deg above the outside temp.
