We just got back from a 6300 mile trip that took us west from Alabama to Colorado Springs, Las Vegas, Los Angeles, San Francisco, Jackson, Yellowstone, Rapid City and back home. Went through several mountain passes, and saw transmission fluid temps hit 250 F several times. The last pass we went up on Hwy 14 near Sheridan Wyoming was by far the most difficult and I had to stop several times going up to allow things to cool down. I refused to allow the transmission to get above 250 or the radiator temp to exceed 225 F. I was really flying blind coming out of Yellowstone, because we had no cell data and I could not solicit the internet for the best route. I chose Hwy 14 over Hwy 26 and that was probably the wrong choice?
So the question I have is 250 F to hot for transmission fluid, and should I change it out now that I'm home and out of the mountains? It still has a pink tint, but not as pink as is was before we left.
Be sure you use Tow/Haul if you have it available. It tends to keep the converter locked and the transmission from hunting and helps with temps. You should have heard the radiator cooling fan come on, hopefully, it is working. I would probably look at an aftermarket trans cooler.
