falconbrother wrote:
I would just do a drain and fill to be safe. I do drain and fills a lot. Takes five minutes and 3.5 quarts of Dex6. If you have to pull the pan it takes considerably longer but, still not a hard job, just messy. If you have to pull the pan put out some cardboard to catch the mess.
On my 4L60e I ground the head of the drain plug off and welded an 11/16 nut in it's place. Plug comes right out. Literally takes five minutes to do the job.
Is that what yours takes? My manual states 5 quarts. But thats with filter changes. I have the 4l60e.
So if I just pull the plug and drain im looking at 3.5 qt?
