looper's avatar
looper
Transmission leaks when towing
This is probably not the place for this post but I'm curious if anyone has experienced this. My tow vehicle is a 2002 Ford 250, 7.3 Powerstroke diesel. I'm towing a 7000 travel trailer. The problem is sometimes, not always, I blow transmission fluid while towing and it leaks out when I stop. The transmission is not overheating, if the gauge is working correctly. I have had the transmission serviced regularly and talked to several dealership service reps about this and they all say nothing appears to be wrong. The leak seemed to have stopped for a period of time and then it started back again today. I'm not positive but I think it has always done this in the hot summer months. I camp more in the cooler months so that may explain the intermittent problem. Any ideas what I'm dealing with before I head to ANOTHER transmission shop?
  • You'll be much more likely to get better help here
    It's where many knowledgeable Ford owners and pros post.
  • First off leaking from where ?
    Vent tube? Maybe your TC is not locking up.
    Hard to determine without knowing where the leak is.
