drumming102's avatar
drumming102
Transmission Temp 08 1500 Silverado
Hey gang.
I'm hauling a passport 2920BH with a 08' silveardo 1500 Crew cab.
My normal Tranny temps when not pulling run about 160. When towing I can get up to 210-220 on the highway.
What is too high? Every person I ask says there really is no set temp but it is kinda proportional compared to your non-towing temp. Is that true?
No I don't have weights to give in the post as I have not done them. The TT is not close to it's max weight and the Silverado should be well under it's max Tow weight.
  • drumming102 wrote:
    Hey gang.
    There is no real thing as to high. It's a proportional thing. The closer you get to 300+ degrees the faster the ATF and seals in the transmission will break down.
    That being said, the modern ATV is very good stuff and will last a very long time. Some modern transmissions don't even have a way to refill them. They are sealed from the factory and will last the life of the transmission.
    210 to 220F for modern ATF is nothing to worry about.
