Hi, the camper weighs 1740 lb,s truck, Rear Axel GAWR 3800
Front axel GAWR 3450 GVWR 6700 That is all I have for now.
That enough for how much weight the truck can carry in the bed on the rear axle.
Actual scaled front and rear axle weights work best.
Many F150 owners report their trucks rear axle scales in the 2300-2500 lb range depending on how each truck is configured. This leaves approx 1300-1500 lbs for a in the bed payload.
Some folks mod the truck to carry more weight ie; higher capacity tires/wheels and rear spring pack help.
Fords F150 3800 lb rating is one of the smaller gawr Ford offers. Moving up is a 4050...4550...4800 rawrs.
The F150HDPP has the 4800 rawr and is good for around 2500 lbs in the bed.
Weigh the trucks F&R axles so you can figure a matching weight camper.
