trvlr619 wrote:
buyer beware. I bought a 2021 rayzr there were gaps in the caulking. It was advertised having a fiberglass roof and fully insulated. It has a rubber roof. There is no caulking or seal where they cut a hole in the wall for the ac to keep rain, bugs out of the wall space. The pan to catch the rain that blows in isn't wide enough.The screen will not keep bugs out and there is a 1" gap above the ac where they can come in and there is a hole in the wall of the ac cabinet where the power cord runs and they can go thru to get in the living quarters. Air from outside can get in too. If you have a rayzr look to see if you have holes between ac and refer compartment. If so you can get exhaust gasses when running on propane.The knee walls are not insulated and there is none behind the propane compartment.
I can't comment on the roof but the rest sounds like a job started but never finished. I wish people would be more forthcoming with info.
