Kennedy64
Apr 29, 2015Explorer
On my Jayco 23b, we pulled the tank off underneath, replaced the plywood, after spraying it with rubber coated stuff (sorry can't remember what it's called). We then went inside pulled up the rotten wood all the way down, used 2x4's as floor joist, a layer of plywood then luan and replaced the vinyl. Not sure if there are joists throughout because we only had to fix a spot probably 3'x3.5'
