intheburbs
Aug 24, 2014Explorer
Beachums wrote:intheburbs wrote:
Well, looking at a 2014 Expedition EL online, these are the numbers:
GVWR: 7720
RAWR: 4250
FAWR: 3700
Payload: 1435
The payload number is surprisingly low, but probably because it's a loaded Limited.
Doing the math, that sucker has the same curb weight as my 2500 Burb. At least I get a 2088-lb payload. Is Ford still that clueless?
Well, comparing apples to oranges would make me wonder who is clueless. Maybe it's me.
What year is your Burb?
Also, the Burb has a live rear axle, while the Ford has a fully independent rear suspension. This could explain the perceived weight disparity that you speak of.
I guess I should have expected at least one Expy owner to be butthurt.
My Burb is an 08, as shown in my sig.
So the Expy has a fully independent rear suspension. Thanks for the commercial. I don't care - I'm just looking at weights.
I don't see it as an apples/oranges comparison, because these are the best SUV options for tow vehicles from Ford or Chevy. Yes, the Excursion is an awesome TV, even superior to the Suburban 2500, but the newest Excursion is now a 9 year old truck on an even older platform. So if you want a Ford that's newer than an '05, the Expy EL is your only choice. So is it fair to compare to the best Chevy offered until 2013? I think so.
Here are the numbers:
Expy EL above: 7720-1435=6285 curb weight
Suburban 2500: 8600-2088=6512 curb weight.
So, the Suburban is only 227 lbs heavier on curb weight, but offers 653 lbs of additional payload. That is the disparity that I was addressing with my "clueless" comment. How can Ford build such a whale with such a low payload?
And since payload is really all that matters on an SUV TV, which is the better choice? Trailer weight rating is a meaningless number on an SUV, because it is almost never the limiting number. Most folks don't tow solo with no cargo.
And going back to the OP's question and some of the comments - a good WDH does nothing to address the vehicle's payload capacity. Yes, it will help reduce weight on the rear axle and make the rig more stable, but it doesn't change the 7200 GVWR. If the trailer tongue weight causes the GVW to exceed 7200 lbs, it doesn't matter. I honestly don't understand how some folks don't understand this.
