CampVirginia
Jan 23, 2014Explorer
Just a short checklist that may save you a few headaches. This was Copied from the Open Range Owners Forum and some items may not apply. But it's an excellent list to start with
Happy Camping!
GENERAL
Second set of keys? Full set of manuals?
Ask about the rod that allows you to open the top hatches so you don't have to use a step stool. (?)
OUTSIDE
Running gear
• Tires balanced, at correct pressure and lugs torqued correctly?
CHECK AGAIN AT 50 & 100 MILES!
• Are the tire valve stems metal? (Will need for TPMS.)
• Check operation of landing gear, front and rear. Locate the remote control.
• Check that Auto-level system has been calibrated (if present).
• Check operation & installation of StrongArm stabilizers. Locate the “T-Handler” extension handle.
• Check that equalizer (between the springs) has grease zerks and has been lubricated. (Consider the wet-bolt upgrade.)
Lights
• All exterior lights working? (Flood lights, porch light, hitch light, brake and clearance lights)
• Are front and rear marker lights caulked correctly?
Accessories
• Operate and inspect power awning.
Slide-outs
• Operate all slide-outs and ensure slide-out cables are properly aligned.
• Do the slide seals appear in good shape where the cables come through?
• Is the spring connected to the Flex-guard cable holder(s) under the slide-out(s)?
Storage areas
• Check all of the outside storage doors for proper operation of the latches.
Electrical
• 12V Deep Cycle Battery? Check that battery connections are tight. Inspect battery holder for cracks.
Plumbing
• Does the black tank flush work correctly?
• Verify that the gray and black tank valves are labeled correctly in the convenience center.
• Check water heater by-pass.
• Fresh water/city water connections working correctly?
• Check all water connections to ensure that they are tight with no leaks.
Propane
• Tanks filled and secured? Check for leaks.
Tools
• Where is the crank for manually operating the landing gear?
• Where are the rods for manually opening the slides with a power drill?
• Where is spare tire lowering crank? (may be in the basement area) Find and test. Is spare fully raised?
INSIDE
Appliances
• Check & operate all appliances.
• Is the bag installed in the Central Vac (if ordered)?
AV System
• Where are the TV and stereo remotes?
• Bring a CD and DVD to test operation of AV system.
• Verify that the TVs are connected to the antenna and that each of the satellite coax connections work correctly (and you understand them). Power on each TV and check antenna reception.
Electrical
• Check all light fixtures for discoloration and/or deteriorating plastic. Make sure all bulbs are good.
• (Convert to LEDs when you can)
Furniture
• Test operation of both recliners
• Inspect all cabinets, drawers, chairs, tables and bedroom bureau.
• Check bedroom wardrobe doors for latches and proper operation.
HVAC
• Is/are the A/C unit(s) noisy? Is it/are they actually cooling correctly (no obstructions, no air leaks at the main unit). Run for at least 5-10 minutes to determine proper cooling.
• Check furnace air flow - is it sufficient at all vents? Any restrictions?
Plumbing
• Does the toilet hold water after flushing? (make sure it does not leak - check water level after 10 minutes)
• Check caulking around shower enclosure. Test for leaks.
• Check all plumbing fittings for leaks (both fresh water and drains) – hand-tighten all drain fittings.
Windows & Doors
• Do all the windows operate smoothly? Screens present and undamaged?
• Check for fit of door and screen door (look for gaps)
Happy Camping!
GENERAL
OUTSIDE
Running gear
Lights
Accessories
Slide-outs
Storage areas
Electrical
Plumbing
Propane
Tools
INSIDE
Appliances
AV System
Electrical
Furniture
HVAC
Plumbing
Windows & Doors
