Locky
May 15, 2013Explorer
Yes that is smaller than your standard residential. But there is enough wood there to chisel out to make it work. Your hole into the wood needs to be minimal 5/8 wide and 3/4 high. And that is cutting it to close assuming the latch and strike are going to line up perfectly. Take a pencil and mark out the hole section on the strike. Remove the strike and with a sharp chisel carefully chisel it out and reinstall the strike.
44,056 PostsLatest Activity: May 04, 2014
