fishn-tin-sean
May 15, 2013Explorer
Locky wrote:
Yes that is smaller than your standard residential. But there is enough wood there to chisel out to make it work. Your hole into the wood needs to be minimal 5/8 wide and 3/4 high. And that is cutting it to close assuming the latch and strike are going to line up perfectly. Take a pencil and mark out the hole section on the strike. Remove the strike and with a sharp chisel carefully chisel it out and reinstall the strike.
The above is correct. Home Depot bath set, trace strike pattern and chisel carefully.
44,056 PostsLatest Activity: May 04, 2014
