ElbyJ's avatar
ElbyJ
Travel Trailer Battery
First time TT family. Went out 3 times last summer. No issues with the battery. Did the recommended thing and removed the battery during the winter and put in our garage. Last month we took the TT to the dealer to have it check over for the summer. Put the battery in and it was totally dead. The dealer recharged the battery and I parked it at the RV storage lot. When out yesterday to check out everything before we leave in a few days and the battery was dead again. The battery is probably only 2 years old (max). Going to have to get a new one before Wednesday. Is there something I am missing in owning a TT and working with the battery. Do we remove the battery after each trip so it doesn't drain or how do avoid having dead batteries all the time.
  • Yes, ElbyJ, you need to disconnect it between trips or arrange for some type of trickle charger, maintainer charge to be placed in the battery.
    Most RV's have enough "parasitic" draws that it will kill a battery in a few days to a week from a full charge. Radio, circuit boards on the appliances, gas/smoke detectors, etc. To prevent their batteries from being dead all the time, many people install a BATTERY CUTOFF SWITCH like one of the ones pictured.
    Other options are leaving the trailer plugged into shore power or adding solar to keep it charged or hooking it up to a battery smart charger (3 stage). If using one of these, check the batteries water level once in a while (60-90 days) to make sure it don't boil dry.
    Use this opportunity to decide if you want to get a bigger capacity battery that might extend the amount of time you can camp with power when not using shore power. If that's something you do, now's the opportunity to buy bigger or multiple batteries as you want to replace batteries as a system, together, not add a new one to old ones.
    Hope all this helps. Good Luck!
  • Will your trailer charging system overcharge your battery of kept plugged in? I am going into my fourth summer with my current battery, and it is plugged in from early May to mid October and is only unplugged when I am hauling it. Battery is still strong as an ox. In the winter, I just put my battery in the garage and make sure it is not sitting directly on concrete. I know I should have a battery tender, or at least put a charge on it once a month during the winter, but I never seem to get around to it and I know that my battery will likelyrematurely fail at some point.
    Also, check the water levels in the battery. If the water is below the plates in any cell, then your battery is likely toast.
  • Also do not store the battery on concrete. Put wood under it when storing.
  • Many of us use a battery disconnect switch when in storage. It's not hard to install one.
  • Check out a product called battery tender. It will trickle charge your battery when not in use,your trailer charging system will more than likely overcharge if left plugged in all of the time.
