- DurbExplorerOlivers have an aluminum running frame and no framing in the walls or roof. Bigfoot has a steel frame and no framing in the walls and roof. Neither has a roof membrane, nor seams, nor seam caulking. They are as close to a no-leak roof as you can get.
- djsamuelNomad
GrandpaKip wrote:
I believe older Camp-Lites were all aluminum, no wood at all.
Correct. The Camplites are constructed of all aluminum framing, including a welded aluminum frame to include even the cabinetry, as well as an aluminum "chassis". On models prior to 2016 (I believe) the roof is aluminum. My Camplite is a 2013 and has been a really nice and reliable camper so far. It is a huge shame Thor killed it. - gerpetersExplorerI posted here to educate myself. I appreciate all the good info. Thank you!
- tragusa3ExplorerOP, you are getting some sound comments, but I understand what you are saying and believe you are on the right track. Just add a few of the other suggestions to your requirements.
Our first was an entry level TT and we then moved to a Surveyor because it was 6 sided aluminum. It still wasn't anything to be prideful of, but it was a very clear step in the right direction! Nothing broke in the hundreds of nights we used it.
I used price point to help me shop. By that, I mean find the middle price for trailers of the length you want. You almost always get what you pay for, and manufacturers have to justify why they are asking what they are. For instance, our Surveyor was about $22k while a comparable in an entry level was about $15k. It was very easy to find the $7k extra once I got to know the trailer. I began to recognize that sometimes more money translates to better value.
You'll figure this out. Keep educating yourself and try not to make a move until you do. - BillyBob_JimExplorer
gerpeters wrote:
I have been researching the Rockwood line up from Forest River and I'm pretty sure I will get something better than a Zinger. Something that would have been leaking since day one is not an RV that WILL leak one day. That is an RV that is already leaking water the day it came out the door.
Yes I fully understand that maintenance is key but there is a difference between buying a Hyundai and Audi. As the saying goes you get what you pay for
Rockwood / Flagstaff can build some decent stuff, but they can also pump out some garbage. If you search in depth at Forest River forums you can het some good info. You just have to weed out the Forest River Kool Aid drinkers on that site who chastise everyone, even more so new members, and contend every little issue is the purchasers fault as Forest River does no wrong in their eyes. They have quite a few of those drinkers including some of the moderators. - GdetrailerExplorer III
Well how about Airstreams?
They are not "cheap" by any means, an tiny Bambi (single axle) WILL set you back a cool $35K NEW and larger ones well above $130K NEW..
See HERE
BUT, they too LEAK AND ROT.
You are only fooling yourself into thinking spending more will result in one not leaking or rotting.
Spend away and live in a dream world, I am out of here, nothing to see..
You can lead a horse to water but you can't make it drink (you can however drown it with knowledge).. - gerpetersExplorerI have been researching the Rockwood line up from Forest River and I'm pretty sure I will get something better than a Zinger. Something that would have been leaking since day one is not an RV that WILL leak one day. That is an RV that is already leaking water the day it came out the door.
Yes I fully understand that maintenance is key but there is a difference between buying a Hyundai and Audi. As the saying goes you get what you pay for - GdetrailerExplorer III
gerpeters wrote:
I bought a used 2012 Zinger from Crossroads 3 years ago. That was the first mistake. Never again will I buy a used trailer. I did not have any experience buying an RV and it is my second one. The first one was too small but a pretty good trailer which served me well for a few years.
The Zinger, on the other hand, I could say that it is junk. I fixed the water leak in the front but this last weekend I decided that I would take off the corner moldings in the back to reseal/redo them.
Both corners are rotten badly including the floor. I'm sure this RV has been leaking water since the day it came of the assembly line
Which shows that even buying "NEW" does not "guarantee" it will not rot.
It wasn't the fact you bought a used TT, it was the fact that the PREVIOUS OWNER(S) FAILED to do BASIC annual maintenance.
Only two types of RVs, one that IS leaking that WILL be leaking.
You MUST INSPECT all of the possible points of water intrusion from the roof down to windows and doors AND all of the TRIM AND MOLDINGS on a annual basis. Any cracks in the putty/sealant it MUST be removed, cleaned and replaced with new.
RVs are not for "wimps" unless you plan to ignore the maintenance.
Failure to do maintenance is the direct result you have delt with, wasn't the fault of the manufacturer OR they type of construction (wood framed vs aluminum framed).
By blaming the type of framing and only looking at aluminum framing you are eliminating better than 95% of the RVs and it WILL leak and rot just as bad as the wood framed ones you rejected.. - gerpetersExplorerI bought a used 2012 Zinger from Crossroads 3 years ago. That was the first mistake. Never again will I buy a used trailer. I did not have any experience buying an RV and it is my second one. The first one was too small but a pretty good trailer which served me well for a few years.
Both corners are rotten badly including the floor. I'm sure this RV has been leaking water since the day it came of the assembly line - TurnThePageExplorerIf slides/large sizes are not important, get a solid fiberglass model. Oliver and Bigfoot are probably the least likely to leak, and most likely to survive a leak if one occurred. Oliver especially. You gotta pay to play though.
I picked a brand new entry level, wood framed unit 15 years ago, then went over it with a fine tooth comb. It sits outdoors 24/7 through all four seasons, including lots of snow/ice and frost/thaw cycles, yet has never leaked.
I'm leery of slides because they introduce a huge leak vector. If I had covered storage though...
