DallasSteve's avatar
DallasSteve
Nomad II
Dec 28, 2017
Travel Trailer Construction - Exterior Identification
A recent thread addressed the construction of travel trailers and it identified 2 basic styles of construction:
Old - wood stud, fiberglass insulation, aluminum siding
New - aluminum tubing, solid foam insulation, fiberglass skin
When I am browsing travel trailers for sale I see basically two styles of appearance as represented in this photo. Is the bottom-left trailer appearance (with the ridges on the wall) always the Old construction and the top-right (with the flat walls) always the New construction?
  • azdryheat wrote:
    I don't believe any builder is using wood any more. It's good that you're looking into how they're built. Many trailers are built so cheaply it's a wonder they hold together.
    Most still use wood frames:
    2017 Jayco
    2015Forrest River
    2017 Puma
  • That trailer with corrugated siding could well be fiberglass over luan, so smooth vs corrugated is not the way to determine construction.
    In fact, it is aluminum, but just a heads up.
  • They still make wood framed trailers with corrugated aluminum siding.
    It's a price point.
  • azrving wrote:
    They still build new ones with aluminum like the lower pic.
    Oh! (That's a big long Oh!)
    So are you saying some trailers with aluminum frames (not wood) have the aluminum exterior with the ridges?
  • I don't believe any builder is using wood any more. It's good that you're looking into how they're built. Many trailers are built so cheaply it's a wonder they hold together.
  • "Always" is a strong word, so let's say almost always. I can think of one TT made in Canada that looks like your #2 example, but instead of a foam laminate sandwich with aluminum studs the Prolite has thicker molded-fiberglass panels that are bonded together at overlapping points with a sort of adhesive... no framing, As I understand it.
  • They still build new ones with aluminum like the lower pic.
