silver_creek's avatar
silver_creek
Travel Trailer Coupler Height
I have no level place close to my home in order to measure the coupler height of my travel trailer and need the measurement to set the hitch height, does anyone know what the coupler height of a 2012 R-Vision Silver Creek? Thanks for your help!!
  • Thanks for all your help. I will try your solutions. But for reference, is there few standards?
  • Parallel, not level. But most people mix the terms. Any large parking lot will do, like schools after hours, stores, etc. Anyway, every weight distributing hitch comes with an adjustable height ball mount. It adjusts enough for most under bumper receivers.
  • goducks10 wrote:
    You want your TT parallel to the ground, not level. Is the ground that uneven that you can't measure parallel?
    X2, get it where the back and front are the same height from the ground at a common reference point on the trailer.
  • You want your TT parallel to the ground, not level. Is the ground that uneven that you can't measure parallel?
  • I do not have the owners manual.
    Like I said I can not measure the bumpers due to no level ground.
    Does anyone out there have this unit that could give me a real answer? Thanks
  • fla-gypsy wrote:
    The coupler height for my trailer was in the owners manual
    X2
  • The coupler height for my trailer was in the owners manual
  • measure front and back of trailer get them the same then measure coupler then add 1 inch to top of ball
