DE88ROX
May 06, 2013Explorer
"Its just your normal noises in here" Tom Petty
Its going to creak to some degree depending on what you have greased. remember that the bars and chain are under a great deal of tension.
Like other have said, grease the bars ,NOT THE ANTI-SWAY BAR where they hook onto/into your hitch. You will see a dramatic difference in noise.
Also, you might want to make sure that you remove the anti-sway bar prior to backing in. I usually take mine off while im stopped and checking into the campground.
