jeremywatts2005
May 10, 2014Explorer
Yes I was using a pressure regulator on the system. They really never gave me an explanation that was believable as to what happened. They tried to blame the cracked pipes on cold, but it was 45 degrees the night that everything cracked. I suspect it was not cracked at all instead the glue came loose on the pipes or some other failure. Water was squirting out of the outside kitchen sink, water was flowing into the toilet causing it to overflow and water was running into the storage area under the city water connection which in turn flooded the underside of the camper.
44,071 PostsLatest Activity: Aug 16, 2026
