westend
May 13, 2014Explorer
jeremywatts2005 wrote:Understood. I've read where folks are pretty happy with their Primetime rig so that may be a good deal for you.
Part of the deal in getting them to do a rebuy would be the purchase of a new Primetime. I can handle that if the deal is right.
About the water situation. From the OP's posts about multiple failure points and the fact that the inlet actually broke, leads me to believe the failures weren't from too high a pressure but from something else. I would bet that the cause was freezing water in the pipes.
If the mfg's would ever step up to an all PEX layout and install a whole house regulator as standard equipment, I don't think there would be near the same amount of problems. Also, filtration, wouldn't it be nice to have a filter as standard?
44,071 PostsLatest Activity: Aug 16, 2026
