Nvr2loud
May 14, 2014Explorer II
JJBIRISH wrote:
Going on 50 years without the use of a pressure regulator and no failures… in all those years I could have used a booster pump on the public connection to get decent shower pressure, but never had a over pressure problem even once…
good luck with the replacement...
Sure, but that isn't always the case. Some trailers can handle higher water pressure then other trailers can. Mine states maximum 35 PSI, but I have had upwards of 60 PSI without an issue (that was not intentional but failure did not occur) The maximum rating is determined by the component with the lowest rating.
