wtmtnhiker's avatar
wtmtnhiker
Travel trailer for taller person
Hi all,
I've been looking for a tow behind travel trailer for a couple of months and getting a little discouraged. I'm 6'3" and have not found one yet where I comfortably fit in the shower head to toe and many of them width wise. I've been looking in the 18' to 26' range new and used. I only need it to sleep two and weigh 7500 GVW or less. No bunk beds and I prefer tandem axles.
Is there such an animal. Do any of you own one? Thanks!
  • Look at brands with an arched ceiling. We have that and it makes the interior seem a lot bigger. I'm under 6' so doesn't help for that. I don't think I've ever seen a TT with the shower not against the exterior wall but haven't paid attention to that. While an arched ceiling will help a bit, the ceiling height gets back to standard at the exterior wall due to the tapered trusses.
    If you're not a senior citizen yet, wait until you are and you may have lost a couple of inches or more. Problem solved, lol... :)
  • I am 6'4" tall and have same problem. I seldom use RV shower though as we typically do not have water/waste hookup at the type of campgrounds we prefer. I just suffer. :)
    However, there are some lines with taller ceilings. Check out Jayco JayFlight with 81" of interior height.
  • ppine's avatar
    ppine
    Explorer III
    Rockwood, Nash, Arctic Fox, Outdoors RV.
    The Rockwood head room is 6'6".
    Use the outdoor shower if you don't fit.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Good luck. I am 6'1" and have never found one that I could stand upright in the shower anywhere except directly under the skylight. Even there, I had no excess room above me.
