RinconVTR
Mar 22, 2014Explorer
I assume you would want a funnel when your not using a hose? When I fill from a 6 gallon portable tank, I made sure the valve was removable. In in its place, I screwed in a 3/4" NPT hose fitting. Attached a braided piece of clear tubing. Filling is now simple, and without spills.
If you are only referring to filling with a hose, and the hose end doesn't fit into the fill hole so you were trying a funnel, buy this:
http://www.campingworld.com/shopping/item/water-tank-filler-with-shut-off-valve/4674
