popeyemth
Mar 22, 2014Explorer
NanciL wrote:popeyemth wrote:
Add a 6 inch piece of hose to the funnel to get past the neck of the fill spout.
I had to add one to my drinking water hose because the metal "male" end wouldn't go into the filler neck.
Good Luck, Mike
See my OP. there is a piece of tubing 12" long attached to the funnel.
Jack L
Use a bigger outside diameter hose.
Mine fits snug enough to seal the neck .
I believe the OD is one inch. You just have to get samples and try. Most big box stores will give you a couple inches to try.
Good Luck, Mike
