dgtjhatt
Apr 20, 2014Explorer
We had a trailer that the water tank was under the walk around bed so the fill was higher than the water tank as it went threw the outside wall ,then down to the floor and back up to the top of the water tank. If you tried to pour water into the tank it would not work, you have to have water pressure to force water up into tank. The dumbest system I ever saw. I went to Home Depot and bought a 3" sewer line clean out with cap, cut a hole in the top of the tank glued the clean out in place and filled it that way. It was actually easier than filling it from the outside.
