Lynnmor
Apr 20, 2014Explorer II
mayo30 wrote:
I just use a spare 12 volt rv Shur flow pump and garden hose to pump it in from what ever water container I use.My battery leads are short,as I set the pump by the battery case.I can usually fill and empty the jugs in the truck without lifting in and out,by getting close enough to fill taps and Rv.
I use the onboard pump that is already wired to the battery. Just made some simple plumbing modifications. Turn a two valves and turn on the pump... sucks it right in.
