KevSchofield wrote:
RichieW wrote:
KevSchofield wrote:
I spent a weekend with a heat gun and WD-40 removing the old graphics, then did a simple racing stripe (ebay vinyl),
a few new Coleman stickers, a small 'scene' graphic (again from ebay) and some vinyl lettering for "Coleman Caravan"..
Cost was right around $100 for all..
May not look as fancy as it did new, but it looks way better than the cracked, peeling graphics did..
How did you keep the stripes so straight?
The stripes came in 8 foot lengths and had a backing on both sides..
You peel the backing from the side that is going to stick to the surface,
then mist the surface with water and put the stripe on..
Once it was in place you squeegee out the water and peel the protective
backing off leaving just the stripe in place.
It takes a little patience but trust me, putting on the new stripes
was way easier than removing the old ones :)
Looks good. I'm not sure if I want to remove my graphics yet. I'm afraid I'll just make it worse.
