Slowmover
Dec 01, 2013Explorer
One of the major things you have to worry about on high, square, trailer is the cross winds that affect them.
The crude leaf-spring suspension is nearly as great a problem, if not more so. On an independent suspension (torsion flex) the width of the roll is pushed out to the wheel center, and that may be at the trailer side wall, instead of far inboard at the leaf spring mounts. The trailer so equipped is far better able to handle emergency lane changes and road surface hazards (from potholes to trash on the road). It is exceedingly easy to turn over a conventional trailer, and, while wind-handling is a seroius cause, the inabiity of the trailer to handle that problem PLUS poor suspension action can combine to make for a loss-of-control accident.
A TT where the weight of appliances, etc, is concentrated on or very near the axles and low to the ground is obviously best. But the square edged TT (needs a 12-22 degree radius) on leaf-springs itself not optimized, (look under a vehicle to see the differences, especially on a car) with a high ground clearance is nothing but a prescription for trouble. None of this is new, it was well understood more than a half-century ago.
An upgrade to independent suspension could make a real difference, it is cheap insurance so to speak.
Wind loads on a square-edged trailer increase down the length of the TT in a crosswind (there are also much more complicated scenarios), in effect the pressure is greater at the rear, the wind has "loaded up" against the trailer wall and is "pushing" the trailer (in contrast, with an aero TT, the winds pass over and "pull" at the TT, much easier for the TT to deal with). The lack of suspension travel of leaf versus IS just makes thing worse. COG concerns, etc, are all inter-related. Raising a TT to avoid problems that could have been solved by, in many cases, better planning, is going backwards when it comes to stability, ergo, safety.
Weighing the TT on a certified scale, empty (full propane and fresh water + permanent supplies aboard), first, and then loaded for camping at each wheel position so as to confirm best loading is the cheapest yet "help" for the permanently compromised conventional TT. Obviously, setting the WDH at the same time to solid numerical values is part of that, as is TV tire pressure reflecting these actual loadings.
Start somewhere.
Start somewhere.
