Community Alumni
Mar 12, 2015Not applicable
Yeah, the inspection requirement has been on the books for years now. Like others have said it's been lightly enforce until now with the one sticker system. The same reality check is happening to motorcycle guys and gals. It's just a regular safety inspection they have to perform, just as they would with a car. It's only like $7 at the station.
Use the link below to find the nearest station. Look for TL or TLMC in the Endorsements column.
Link
05.06 Inspect All Trailers, Semitrailers, Pole Trailers, or Mobile Homes Exceeding 4,500 Pounds Actual Gross Weight or Registered Weight For: (Listed in suggested order of inspection) Refer to Federal Motor Carrier Safety Regulations, if required.
* Check for evidence of Financial Responsibility on towing vehicle
1. Brakes (system) (If gross weight exceeds 4,500 pounds)
2. Tires
3. Wheel Assembly
4. Safety Guards or Flaps (if four tires or more on rearmost axle) Pole trailers exempt.
5. Tail Lamps (2)
6. Stop Lamps (2)
7. License Plate Lamp (1)
8. Rear Red Reflectors (2)
9. Turn Signal Lamps
10. Clearance Lamps
11. Side Marker Lamps
12. Side Reflectors
13. Side Marker Lamps and Reflectors (30 feet or more in overall length)
(Refer to Reference Section as per lighting diagrams and as applicable to the particular trailer being inspected.)
14. Serial or Vehicle Identification Number
15. Window Tint.
Link
2. Tires
3. Wheel Assembly
5. Tail Lamps (2)
6. Stop Lamps (2)
10. Clearance Lamps
12. Side Reflectors
15. Window Tint.
