fla-gypsy
May 20, 2013Explorer
Did you have the HWH or fridge on elec? In my keystone Hornet I can run my MW and my AC at the same time along with the fridge if all 3 are not powering up at the same time. Adding the WH to the mix will sometimes blow the breaker. When you say the CB is tripping, do you mean the inetrnal 30 amp or the power pole 30 amp? Have you tried using an adapter and using the 50 amp plug? many 30A receptacles are worn out from use and do not supply good power. Have you checked the voltage and amperage at the supply receptacle? What is the internal voltage you are seeing? As voltage drops (common in older CG systems) amperage is increased and can lead to CB's tripping.
