Terryallan
Jan 29, 2020Explorer II
Hannibal wrote:
Auto leveling shouldn’t matter. I would adjust the WDH to bring the front of the TV back down about half way between loaded and unloaded.
But it does. IF you adjust the hitch when the vehicle is down, / before the air ride levels it, and then tow with the vehicle raised. It changes the way the weight is distributed. And so the front may still be light.
And if you adjust the hitch with the vehicle running, and air ride on. It compensates while you are adjusting, and you will never get it right. Remember. The front has air bags as well.
