Terryallan
Jan 30, 2020Explorer II
HawkTX wrote:kellem wrote:
The Equalizer is very nice and likely the most popular.
Unless you're doing a lot of boondocking I wouldn't worry about a top end battery.
If you can keep your trailer plugged in at home,they'll last for years.
We do quite a bit of boondocking. That's why I was thinking the deep cycles would be a good idea. Even thinking about throwing some solar on the roof.
I would also go with the deep cycle. If you are like us. Even when we camp with full hookups, We use the battery to raise and lower the tongue jack, and sometimes put out the slide. We also use the fridge on propane in route, and have it on before we leave. So a deep cycle does a better job. And with the solar charging it, will last a good long time.
