HawkTX's avatar
HawkTX
Travel Trailer Newb question RE: WDH
My wife and I are not new to the RV world, but new to travel trailers and considering one. Our towing vehicle is a 2016 GMC Yukon Denali with the 6.2L which has the integrated braking controller, rear air leveler, and can tow up to 8500lbs. We are looking at the 2020 FOREST RIVER RV FLAGSTAFF MICRO LITE 22FBS. Which is 23ft 10 inches long and weighs 5004lbs, which I have been told should work nicely. My question is...Do I need a WDH (weight distribution hitch) for this length travel trailer or will I be fine just towing tongue to hitch. I've owned motorhomes and 5th wheels, but this is my first travel trailer.
Looking at a 20ft as well so same question on that one.
Any thoughts and recommendations would be appreciated.
  • I wouldn’t tow without one. It puts weight back on the front wheels making steering safer. Preventing trailer sway is important, also.
    Your hitch rating on the Yukon may require one depending on the real world tongue weight of the trailer.
  • if buying new, press the dealer for a free one. get some sway control too. good change you can get it out of them. don't bring it up until you are done talking price.
  • Sorry,I missed the air level and yes that will prevent sag.
    I'm still an advocate for a WDH with antisway, hard for me to advise against.
    Dealer will likely throw one in during negotiation.
    Yes, I'd recommend a WD hitch.
    I tow a 12' cargo trailer and use a WD hitch.
    The Nash in my signature is pretty small. I tow it with a dually. I've towed it with and without the WD hitch. The combo rides like krap without the WD hitch, so I always use the WD hitch now.
  • kellem wrote:
    Just recently looked at that exact trailer at RV show,very nice floorplan.
    The stated weight is the UVW and doesn't apply to us that tow....you'll be around or slightly above 6k towing but your still in good shape with TV.
    To many advantages of a WDH not to warrant its use. Imo
    The biggest is safety and piece of mind,eliminates sway and keeps the trailer and TV level.
    I towed virtually the same size trailer for 10yrs using a Reese DC WDH.
    Your looking at roughly a 600# tounge weight.....the rear of Yukon will sag.
    Thanks for the post. Will it sag even with the upgraded towing package I have with the "premium Smooth Ride Suspension with the Rear Air Leveler?" I tow a 30ft Triton on a trailer that is longer and when I load it up it always kicks on and levels the back end out.
  • Just recently looked at that exact trailer at RV show,very nice floorplan.
