WhatTheHeck
Jun 25, 2015Explorer
Thank you for your input Dennis.
It is 398 square feet inside.
The length of the unit itself is 33 feet long - add a few more feet for the tongue.
From what they said, if I just do not tie it down then the fees are not required. Maybe I will do this instead and keep it "temporary".
I am a bit discouraged with this. Maybe I will turn around and sell the unit and get a motor home - not sure.
In this case, SIZE does NOT matter to them. They never asked about size when I called. I never told them it was a Park Model travel trailer and they never asked. I simply just said "travel trailer" and nothing else.
They basically said that ANY travel trailer that will be tied down will be considered permanent. Which means even if you had a smaller 16' RPOD travel trailer or even a tiny 13' Scamp. It did not matter the size of the unit - only if it was to be "tied down".
