tkwoodcock
Aug 19, 2015Explorer
APT wrote:
Not tow capacity, payload. Any given vehicle is limited to the lowest of all its ratings. That could be receiver, axles, tow rating, GCWR, etc. A 10,300 pound loaded TT will likely exceed every half ton receiver. If you have 1200 pounds of payload and 1000 pounds of TW, then you have 200 left for driver, passengers, and anything else in the truck bed and cab.
Just make sure yours has enough for what you estimate. Open drivers door and locate this sticker. Note what it has where mine says 2051:
And verify the yellow sticker weight on the actual unit you plan to purchase. I looked at the Jay Flight 31QDBS that were 500-600 pounds over the web site weight. Then I would add fresh water, pots/pans, food, clothes, etc.
Mine shows 1380 in the place where yours says 2051. But my owners manual says 9700 lbs capacity based on my engine and the factory towing capacity. The other sticker says GVWR 7100 lbs and GAWR 4000 front 4150 rear. I think I'm getting a little confused with this. Can you help me out, what size can i really tow? The hitch weight is 855 on one of the trailers, will weight distribution arms not help me?
44,056 PostsLatest Activity: May 04, 2014
