APT
Aug 19, 2015Explorer
A WDH is required over about 600 pounds of tongue weight on every half ton I have seen. If you adjust the WDH such that 100% of front axle weight is restored, then only about 80% of loaded TW should be accounted for in payload. But dry weight will go up, as will dry TW.
Take your 1380 pounds of payload and subtract however much you an family weighs. Maybe that's 300 pounds or 800 pounds - you do not have to disclose. 1380-500=880 pounds for trailer TW. I'd look closer to 650 dry then.
Get a WDH with integrated sway control and learn how to adjust it.
44,056 PostsLatest Activity: May 04, 2014
