tkwoodcock
Aug 20, 2015Explorer
Danattherock wrote:tkwood**** wrote:APT wrote:
A WDH is required over about 600 pounds of tongue weight on every half ton I have seen. If you adjust the WDH such that 100% of front axle weight is restored, then only about 80% of loaded TW should be accounted for in payload. But dry weight will go up, as will dry TW.
Take your 1380 pounds of payload and subtract however much you an family weighs. Maybe that's 300 pounds or 800 pounds - you do not have to disclose. 1380-500=880 pounds for trailer TW. I'd look closer to 650 dry then.
Get a WDH with integrated sway control and learn how to adjust it.
Ok I feel a little better now I was beginning to think the only thing I could tow would be something less than about 5000 lbs.
SO If i'm understanding it correct, and I apologize if I'm not, I need to keep my tongue weight from the TT around say 650 to give me some payload room under the 1380 limit. I need to make sure then that the trailer is not more than about 6000 to 6500 lbs to keep it within the safety margin of the 9000 lbs capacity listed in the owners manual to account for cargo, water and such.
Towing the popup at only 1400 lbs this was not an issue.
There is no way in hell I would consider towing 9,000 lbs with a 1/2 ton truck safe. I realize, that's not what your saying you will do, just being Capt Obvious here. You are smart enough to be doing research, which is why I'm here too.
But I would continue to give lots of consideration to the max I would tow. Nor am I implying you got bad advice before me, just suggesting you continue the conversation with yourself and others.
Just because it's in print, doesn't mean you should do it. Driving down straight interstate, maybe not an issue. However, a Ford Excursion flipped last week in Nash County carrying a 30' white box and it was on a straight section of highway from what I saw on the news.
But think of all the real life issues that could arise. Transfer truck blows your doors off, you barely go over a low shoulder for whatever reason, up and especially down steep grades, slippery road conditions, a tire blows out at 64 mph, braking hard and changing direction to avoid a car pulling out in front of you while going highway speeds, etc.
I lack the experience to answer your question, but have a few questions you need to get answered. And not from folks towing with Tundras. It's a well known fact that they have an over inflated sense of what the truck is capable of and the vast majority that are towing larger travel trailers are overloaded. That's an absolute fact, but I have no proof.
How much the actual WD hitch itself will detract from payload. 100 lbs? More?
How much your camper will actually weigh loaded, which will be far more than manufacturers advertised dry weight.
How much the actual hitch weight will be, again, known to be much higher than manufacturers website. I've heard from many folks it can be hundreds of pounds more.
Being honest with yourself, add weight of any and all gear you will carry in truck bed or cab. That added to all human weight, including driver, added to the actual tongue weight, not advertised tongue weight, and the weight of the WD hitch itself, will give you a better idea on where you stand with payload.
Heard it a million times lately, it's not whether the truck will pull a trailer, it's whether or not it will stop it. Seeing the cause of so many accidents involve, braking, decelerating, going downhill, downhill around curve, etc. It is something I recently gave lots of thought to.
And I was joking about Tundras, their owners just have big buttons sometimes, I like pushing. We saw and loved the Tundra 1794, but payload wasn't near enough.
Dan
Dan, I appreciate all the info it's alot of stuff to understand. I started looking last night at different models and manufacturers, there are some out there that have about half the tongue weight and are only about 4500 lbs but seem to have just as much room. The Coachmen Apex Ultra-Lites look to be more like what we should be looking at. I think I got carried away with the the bells and whistles instead of practicality. I have a buddy who has a custom utility trailer that I think I'm going to load up with different weights behind the Tundra and see how it pulls and stops to see how it will tow.
44,056 PostsLatest Activity: May 04, 2014
