ctabailey
Jul 21, 2015Explorer
These guys are crazy. The OP is brand new to camping, and want to do an extended tour as their first trip.
You guys and your "One Ton - itis" make me LOL.!!!! Inevitably, every single "can I tow with this?" post ends up with - "you better get a ONE TON to pull that pop up!" This stuff is getting ridiculous.
I guarantee every single "you need a one-ton" guy on this board started out with something much, much smaller.
To the OP - you are getting talked into a $60,000 truck!!! not to mention a new 24' Travel Trailer will be around $19 - $20k on average.
Why not try the darn MDX for a while? It's paid off, and two people and a baby do not "need" a 24 foot travel trailer. I commend your minimalist approach. Coachman makes a very cozy 19 foot trailer under 4500 pounds gross, and KZ makes some under 3,500 pounds gross weight.
To the One-Ton crowd: doesn't it make sense to introduce new RVers to our hobby in an "easy" and cost effective manner? Why does every post always end up with "you better get a one ton!" ??
Just because most of use will eventually get a 30 footer, that doesn't mean folks can't try the little trailer route, and use their paid-off family cars for a while.
OP - you might actually end up in a 3/4 ton or a one ton if that's what you really want. We have no idea of your personal finances, nor is it any of our business. But - MOST beginning RVers start off small, and part of the fun of the hobby is "working your way up" into a bigger tow vehicle, and into a bigger RV.
as long as you are safe, and feel safe pulling the camper, have fun! Do not get talked into a diesel one ton right off the bat. They are not necessary, will only cause you extreme costs, and might make your 6 month adventure come to an end prematurely because you have spent all your savings buying fuel.
You know how the oil change for your MDX costs $29.99 at jiffy lube? Well - your oil change on a 3/4 ton or one ton truck will start at $60, maybe even $70. You know how your tires cost you roughly $110 each for your MDX? Try $250 each.
EVERYTHING is more expensive with a big truck.
44,056 PostsLatest Activity: May 04, 2014
