Hammerdown3512
Feb 09, 2020Explorer
Travel Trailer Roof leaks / repair questions
Hello. I need to travel trailer ownership and I just bought a 2015 Recreation by Design Royal 40'non park model with 2 slides.
I have a couple of questions.
I have a leak that I'm pretty sure is where part of the roof meets the sidewall I've been told this is a common area for leaks.
I've been looking at the products to coat roofs with. the dicor specifically, the tape, caulk and roof sealant.
Is this what I should be using for a metal roof?
Am I going about this the right way of sealing the roof entirely to see if that fixes the leak or is there other methods? I figure if I type up all the corners role good and still the entire roof and redo all the dicor around vents what not, ill most likey cure the leak.
Thoughts?
Thank you very much in advance. I'm fresh out of a divorce and I'm gonna have to live in this trailer for a year or 2 woth my kids so ive got to fix this right.
Thoughts?
