wanderingaimles
Jun 02, 2019Explorer
All the manufacturers build different lines, at differing price points.
Forest River for example builds six different brands, (like GM builds chevy, buick, gme, etc) And within them builds multiple models with differing price and accoutrement levels. From entry level to luxury models.
You will see similar floor plans offered in several different trim levels, with the differences visually being Metal vs glass or azdel sided, cabinetry being all wood or differing levels of particle board and like materials. Appliances are similar across the lines with the exception of some of the larger units having 10, 12 or more gallon water heaters, bigger and in some cases residential reefers, and even electric ranges.
Differences you dont readily see are frame size, tank sizes and other systems that are concealed in the unit.
Start by considering how you intend to use the unit.
Occasional weekend or extended trips.
Dry camping or full hookups.
If you have a tow vehicle, what are its limits?
If not, decide on type of trailer and size, and then buy a truck with at least 25% more capability according to the mfr data than the trailer you are planning around. This will allow for a possible "upgrade " in a year if you dont start with a big enough unit. A lot of folks in here lament the truck not being able to tow their trailer as easily as they desire, but it's rare hearing someone complain that they have too much truck.
Happy Motorin
Happy Motorin
