Jebby14
Jun 03, 2019Explorer
valhalla360 wrote:Cantilli wrote:
We have a Dodge Ram 150.
We still need more info. Particularly for 1/2 ton pickups, their capabilities can vary wildly depending on how they were outfitted at the factory.
If you look on the door jam, there should be a yellow sticker with the capabilities for the truck...as it left the factory.
Tow rating is only one item to look at...and often is not the limiting factor.
The most common limiting factor is payload. You have to include passengers, any after market add-ons (ie: hitch, running boards, truck caps, etc...) along with any cargo in the truck. What's left of payload left to support the hitch weight.
Assume 15% of the GVWR of the trailer as the hitch weight is a good starting point. Get too low and you can get handling issues.
So if you have a 2000lb payload and the truck starts with 400lb of passengers and 600lb of cargo...that leaves 1000lb for hitch weight. At 15% that's about 6600lb trailer max...so even if the tow rating is 8000lb, the truck will be over limits.
and theres a good chance that ram has quite a bit less than 2000 lbs payload. a pic of the door sticker will help us help you.
